Haf 932 - cleaning
31 Oct 2007
Gods County(Allegedly)
Having not got around to fitting filters am in habit of cleaning the case every 2/3 weeks. Sad , I know, but i do enjoy.
What has irritated me has been the fact that I could never get the rubber cover which sits on top clean (having gone gray mottled it seemed to want to stay that way :().
Until today - Armorall - rubber & plastic cleaner for cars does a really good job and have no hesitation in recomending :D
Better half is looking over shoulder and letting me know that I really am a sad b...... and she has lots of more productive (i.e. less sad) jobs that I could do. ah well - c'est la vie :p
I know what you mean but fitting filters will raise the temp in the case . Its good practice to clean everthing . I just use a soft paint brush and the vac and it only takes an hour . I remove all the fans and clean them as well. Just about to strip mine and paint the inside. Allso going to mod the steel work so the motherboard sits higher in the case. Leaving more room between power supply and bottom of motherboard.Also running dule power supplies so this will also allow me to mount the other power supply in the case .
I think someone on here has made filters for the HAF and it didn't really affect temps. I have a HAF 932 but it doesn't seem to get that dusty. I agree about the rubber cover though.
Nice spacious case and easiest I have ever worked with.
