HAF 932 Dust
11 Apr 2004
Can anyone with a HAF 932 tell me if it not having dust filters is a major issue? Do you have to periodocialy have to open it up and take it apart to get a build up of dust out?
Thanks.
Doubtful that it will cause any problems. I used to have this old and cheap case, it had no dust filters, opened it up after 4 years of use and only a thin layer on the fans and the base etc. ;)
It would depend on how dusty your environment is. My old Antec 900 used to get loads of dust inside it before I made some ghetto filters out of women's stockings.
i've just got one so can't say how bad the dust problem will be as i'm making some filters for it myself clicky before i rebuild into my new case
and as faffer said will all depend how dusty your home is and things like do you smoke or live next to a busy road and have the windows open.
In my old case I had a serious problem with it; I think because the air wasn't moving fluidly enough. I've had my HAF for a while now, and not had any dust problem at all. With the smart air flow the HAF has the dust is kept moving and can't really settle.
No problems with dust here, using the HAF932.
There is less dust in my HAF932 after 6 months use than there was in my Antec P182 after 4 months use (and the P182 had filters!!!)
