Haf-x and h70 fan directions...
24 Sep 2007
Oxford
Right, I've got a haf-x (spec in sig) and i'm about to be re-cabling it as three red 200mm fans have arrived.
Currently I've got just the stock fans for the case with the 200mm roof fan as an exhaust and everything else as an intake, with the two enermax 120mm fans on the H70 as intakes on the rear of the case.
I'm planning on having everything as an intake except the two 200mm roof fans, is this going to be a good idea or would I be better off taking the hit on the h70 temps and running it as an exhaust as well?
Many have the H70 as an intake as it brings cool air over the radiator. I do this for my H50.
Like you said, everything in my case is intake apart from the roof exhaust fans.
