HAF-X - anyone burned their firewire chip
I was lucky enough to get 1 of the newer ones with PSU filter and a piece of clear plastic to protect the front panel pcb. I knew of the issue beforehand, and I also reinforced the troublesome area with insulation tape. There are horror stories of motherboards being fried as soon as a usb or other device is used on the front panel :eek:.
Yeah, read about them. Was curious if anyone had one which killed their board. I was buying one today from OCUK for my brother. In the end chickened out and changed my order to a 600T.
Was not aware of this problem, but then again, i removed all cables to front panel except the USB's, when i first got my case, and Firewire is disabled in my BIOS...
Apart from that, this case rocks...
Red
I read that a while back, didn't put me off buying, just made sure i checked it first, it was all neat and tidy.
