Hi, I have just bought a second MSI Twin Frozr 580 from here and am now running an SLI rig. I have a HAF X and a p8p67 deluxe mobo. I get a good bit of distance between the 2 GPUs but the temps on my top card are reaching 90. I know this isn't awful but I would like to get those temps down a bit.
My fans are set up as default so that is 1 intake at the front, 1 intake at the side then 2 exhausts, one at the top rear and one at the back. I also have a thermaltake frio cpu cooler.
So, what should I do? Should I change the side panel fan, should I change all the fans? Should I add in a second top fan. I'm not interested in water cooling and I like negative pressure cases. I clean my computer and the cable management is good. My budget is anything under £150 (although less is best).
