Haf X fan replacement
Permabanned
15 Sep 2010
Ok guys could anyone please help/advise on fan replacement for the Haf X?
I want an all blue led theme and am looking to change the front and top fans.
I will be getting two fans for the top and one for the front, which ones are the best to go for, preferably molex powered so as I can hide everything in the cable management compartment.
XIGMATEK Cooling System XLF XLF-F2006 200mm LED Blue Case Fan PSU Molex Adapter/extender included
Works perfect. Is more quiet than stock fan though puts out slightly less CFM's (~110 OEM vs. 76. They are actually 20mm vs. the stock 30mm.
You can also go with the stock fans if you like the performance of them...COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case Fan
Both of these work as stock replacements for front and top.
The front is noted as a 230 but that would be an oval frame shaped 230mm. The 200mm fan is a direct replacement for top and front.
I got a replacement megaflow off ebay but it didn't have the switch cable to turn the LED on or off, it just just on constantly, I believe you can find them with the switch cable included though.
Edit: I just found the blue LED direct replacement (clear plastic) on another site, obviously I can't link to it but I think the product name is COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case Fan
