Case: HAF X
Motherboard: Asus P8Z77-V PRO
Fans:
Front: 230 x 30 mm red LED fan with LED switch x1 / 700 RPM / 19 dBA
Top: 200 x 30 mm fans x 2 / 700 RPM / 19 dBA (I will only use one)
Side: 200 x 30 mm fan x 1 / 700 RPM / 19 dBA
Rear: 140 x 25 mm fan x 1 / 1200 RPM / 19 dBA
Which fans should I connect to the mobo with the 3 pin connector, the 2 molex connectors on every fan should be connected to the PSU and the other molex should be connected from the PSU?
Where does number 2 go and what is it? (I Know number 1 goes into the mobo.)
Fans:
