- 6 Oct 2010
Hi guys,
Im in the middle of a new build of parts from OCUK using a HAF X case.
Aside from hitting a bit of an issue with the GFX 570 bracket not lining up with the screw holes on the case (resolved with a combo of case pushing from the back and a bit of a bend to the 570 bracket) its been a joy to work on until....
I tried to install a 3.5 inch HDD. I have an SSd for the OS so this is just going to be a data storage drive. The HAF-X drive bays come with 4 pins through silicone/elastic rubbers. You are supposed to bend the caddy slightly, push one side of the drive onto the two caddy pins and then close it and locate the other two pins on the other side.
Sadly, my pins will not go into the holes of the Seagate baracuda 1Tb drive i just bought.
im a bit shocked. Ive pulled the pins out the caddy and just simply tried pressing them in the holes and they arent even close to fitting.
Ive reassembled the drive about 10 times trying various wiggles and stuff and even when the pins look like they are in, they are still proud enough to stop the caddy sliding back into the case.
Any ideas anyone? (ive tried all the caddys by the way - same story)
Thanks
Matt
Thanks
Matt
