Haf X Hot Swap?
I think that AHCI needs to be enabled in the BIOS for hot swapping to work.
AHCI must be enabled before installing Windows and there will be problems if you try and enable it retrospectively.
Guide to enabling AHCI after windows is installed:
Open Regedit
go to Hkey_Local_Machine -> System -> CurrentControlSet -> Services -> msahci
and change 'Start' to 0.
Ive used this method before and it does work (only tried in windows 7).
