Haf-X issues...
20 Feb 2009
Ashton-Under-Lyne
Had a Haf-X since I upgraded to Sandybridge back in Jan, but a couple of things have bothered me about it, so I just wondered if they are issues with all the cases, or if I just have a dodgy one.
First, in the hotswap bays, the screw holes to mount the HDDs don't actually line up right. I can get 2 screws in, but the others don't line up (it's only very slightly off though) - This happens in both bays, whatever HDD I try.
Secondly, I decided to add a second 200mm fan to the top of the case, however when I did, I had to remove the USB3 cables from the front panel, as the connects stick out too far, and hit the fan, and as such the top of the case can't be put back on.
The second issue I'm sure is universal, as it's more likely a design issue, rather than error in manufacture, but what about the drive bays? was there an issue with the calibration of the drill/punch they use for the holes on the day my case was manufactured, or is it a constant problem?
I have a drive in the hotswap bay fine, if I recall, the screws did seem a little off but not enough to be a problem and all 4 are used. Haven't stuck in an extra fan so no experience with that.
I had no issues fitting a second 200mm fan on the top and keeping the usb3.0 cables. You just have to make sure they're right out of the way as you put it in and run them round and down.
Not sure about the hot swap bays as i've removed mine as I've plans for a dual 5.25" reservoir and I'll need the space.
