haf X or corsair 650D
Which do you think looks better?
Do you think you'll require a full tower case?
The Haf X will probably run your componants slightly cooler but not by that much I presume.
Form or function really, its up to the individual, my Haf X sits under the desk so I rarely see it, its not actually quite as ugly as I thought, but it ticks every box on the list in terms of, massive amounts of space to work in, support for massive gpu heatsinks on a couple diff cards, good for cable routing, etc, etc.
Corsair, for me, is less functional, less good cooling, space, function, etc, etc, but much nicer looking.
Ouch, I thought i'd check for the sake of it just to check I wasn't talking about the wrong Corsair case. The Haf X has gotten silly expensive, I got one only a few months ago for £110ex vat, but its like £160 now, ridiculous. It is, IMHO a lot better than the Corsair but, now more expensive. Not sure if thats OCUK prices, a Haf X at along the lines of £130 is pretty much unbeatable, at £160, its less good value but still a good case.
No idea why the price would go up so much though.
I like the haf X also, but the price of it now is £160. :( I found some haf X in ebay that are much cheaper. should I just buy it there? what do you guys think?
the 650D is sexy. The HAF X not so much. Internally, i suspect theyre both great to work on. More room in the HAF X but the 650 is still huge, for a midi.
The choice between a 650D and the HAF X came down to which would fit my desk. The 650D being not quite as tall just pipped the HAF X.
Its my first proper case. Solid, quiet, no vibrations. I did pull the HHD LED connection because the white LED was a bit to bright for my taste.
Yeah, the HAFX is an awesome case, if you don't mind the looks. It's got everything for a good budget. If I had the choice, I would pick up the corsair though, personnal preference (I like a good looking case, and the Corsair is very competent in all departments anyway).
Don't think you could go wrong with either.
Overall the Haf may better case giving you options to use the extra large motherboards but I still ended up with the 650d. The easy access disk doc station
sold it for me.
