Did you have any problems with cables or did all they fit even if they went round the back of the case for cable management?
I'm upgrading to this case soon and my biggest worry is that the cables won't fit, and extension cables aren't particularly cheap either when you add them all up.
Cheers.
Cheers.
All mine fit behind, it does push off the side if you take out the thumb screws though. I also disconnected the USB3 lead, firewire and audio leads as I won't need them.
