Does anyone know if i could swap out the 1 large 200mm fan already installed at the top for 3 x 120mm regular case fans doing the same job of extracting heat, i know you can put a 360 rad up top, but im not sure if thats the same as putting just 3 fans up there on their own without the rad, will this work? need a definate answer please as im ordering the case today and i dont wanna waste money buying the extra fans if they wont install correctly.
Thanks in advance for any help.
