HAF X, Sata Cables (quick question).
14 Apr 2011
So I got a computer to build inside a HAF X. My mobo came with 2 Sata cables, my computer needs 3 (SSD, HDD and DVD Drive). But at the angle at which the Sata cables need to sit for the HDD and SSD as they are mounted sideways, would I be better picking up a couple of L-shaped sata cables? Or doesn't it matter?
Cheers.
It dosent matter what SATA cables are used, just buy the ones that fit the bill the best, whatever ones make it easier for you?
I just figured because the socket on the HDD and SSD would be near the side of the case, an L shape might be better. If it really doesn't matter, I'm pretty much good to go as is.
If you're sata cables from the mobo are in the plain of the motherboard then you ideally want the straight ones, if they're mounted vertically out of the mobo then you'll want 1/2 straight and 1/2 right angle.
Alternatively use all right angles, mount half the HDD upside down and use the L-end on the hard drive which should be a lot neater.
