- 22 Oct 2009
Morning all.
Got my Haf-x a couple of weeks ago as I'm gradually building up my components for my next build. Have also purchased coolermaster megaflow fans for the top of the case. The case comes with one top fan installed which I am going to replace with a megaflow one.
Now, when i went to install one of the fans I noticed the mounting holes are particularly small. Too small for the screws to go through. Also, the pre-installed fan has different screws to the rest of the case fans.
So I'm wondering, whats the best solution? The screws that fit the hole in the case are too small for the fan hole and vice-versa. Any tips would be helpful.
Thanks, Ian
Thanks, Ian
