Heya guys, seen a HAF xb build log and it made me want one, immediately. I have a few questions though.
Firstly I'd like to know whether a TY-140 fan would fit the in the rear? It's a 120 mount fan.
Secondly, would you recommend using an air cooler or would I be better off getting a closed CPU loop e.g h100
And finally, would you even bother to use 2x 80mm fans on the rear?
Cheers!
Cheers!
cheers!
