Keep them the same, i swapped my side fan for 4 120mm Coolermaster green and red LED fans and now although it looks bright and coulorful enough, there is too much air going and not enough being sucked out causing a lot of dust to build up, the stock fans create a negative (?) air pressure and you got very very little dust, now im having to clean it out every month as apposed to never having to clean it out in 6 months with the stock fans
