I've recently had my kitchen plastered (re skim on old plaster , and since painted etc and had some hairline cracks appear above one of the radiators (the large one ).
Generally none of the other walls have this issue (one bit on a corner near a window) and the plasterer came back to do another section and mentioned it the thermal expansion/contraction.
My plasterer suggested just repainting over the cracks but surely it will re appear? It's dulux kitchen paint which I imagine is fairly flexible. As its happened in few areas I don't think it's a wider issue.
Ive read online and it suggested decorators caulk, then sand then paint?
Maybe just sand and paint first and see if that works?
It's the wall with the large radiator I previously posted here
https://forums.overclockers.co.uk/posts/31327584/
