- 31 Oct 2005
- Yorkshire
"reboot and select proper boot device"
Hi There,
So i finally decided to defragment my hard drive today while i went to work only to come back to a black screen saying;
"Reboot and select the proper boot device. Or insert boot
media in selected boot device and press a key"
Thought id restart it and use the repair console which didnt work however when i rebooted to hard drive i get the following;
"Windows cannot start because of the following file is either missing or corrupt:<windows root>/system 32\hal.dll"
It wont pick up any CD's i put in and no matter how many times i restart it just says the same thing, i've got a lot of valuable stuff on there i really dont want to lose if possible. Only solution i can think of so far is buying a cheap HD drive>installing XP>recovering info>formatting but wondering if anyone has anymore ideas i can try?
Thanks
Hi There,
Thanks
