Half builds spec help
29 Mar 2011
Had a custom build,but it will no longer turn on, don't have the time or means for testing
No sign of power to my board,so not sure if its that or psu.
Already have, and going to assume still works
Graphics card
Ram
Cooler and CPU
Hdd although another wont hurt
Blu ray drive
So potentially looking at a mobo and psu bundle,gonna order the next phantom to put it in, something quite overclocking friendly would be good as not over confident with it
Been out of the PC game for a bit,will that mobo offer similar performance, and will that psu been fine for possible upgrades and crossfire?
Graphics card
Ram
Cooler and CPU
Blu ray drive
Have you tried another PSU at all?
Does your Mobo have a power light on it?
What is your budget for this bundle?
For xfire you would need at least 750w and the mobo should get you 4.7Ghz on the 2500k.
Was given a bit of extra funding so ordered these.
Antec High Current Pro 850W Modular '80 Plus Gold' Power Supply £108.32 1 £108.32
MSI Z77A-GD65 Intel Z77 (Socket 1155) DDR3 Motherboard £108.32 1 £108.32
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Red £83.32 1 £83.32
Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £43.32 1 £43.32
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £34.99 1 £34.99
Should last a fair while
