Half height AGP card
What do you use your comp for and sorry if I'm being dippy here, but what do you mean by half hight? ... half as long or half as wide?
games or just for general use?
6200 can be had for around 25 quid. has purevideo support and is low power consumption and low heat output. passive cooling too.
£65inc vat and delivery will get you a 7600gs agp, absolutly brilliant card can be used for decent gaming and has nearly all the feaures of purevideo according to nvidia's chart. i have a 7600gs agp myself and its a bloody brilliant card.
Cyber-Mav said:
agp or pci-e, games or just for general use?
Says AGP in the title :confused: (Edited now - Ninja skillz :D)
If its just for office use then go with cheapest you can find really.
Don't think there's a half height version of the 7600GS is there?
bloody hell your really quick, i noticed that he had agp mentioned after i posted my post, but i edited it in lick 30 seconds so you must have jammied it somehow. i was so fast on the edit that it does even show up in my above post as it being edited.
do some overclocking. i find that always helps to pass the time.
or play a bit of jenga with your pc, delete files from your system32 directory and see how long it takes for the pc to become unstable, best played with 2 or more players, keep taking turns to delete files and the one who deletes the file that crashes the pc = winner :D
Check my thread in the MM, half height passive 9200se :p
Runs Q3 engine games well at 1024x768!!
(please, for the love of god, don't suspend me again)
looking for something with a wee bit more poke than that mate
trojan698 said:
Pah! you might be struggling being restricted to half height. Does it have to be half height?
no i suppose not ...
i could hack away at the plastic part of the case with a breadknife and make an ugly gash large enough to slot a full size card in ...
have already found a 9550, that has more poke than your 9200SE doesnt it ?
RaMDOM said:
btw - the term is 'low-profile', not half height. Just for future reference. :)
i knew that mate
half height describes it better, and people who dont get "low profile" will certainly know what half height is
kapish ?
