- 31 Oct 2005
- Leeds
well basically seeing as you are all raving on about ep 1 i thought id attempt to complete this
so i installed it on my shuttle that uses the 27 inch sammy as a monitor
it works fine, great i think im off now!
then i notice its running in 800 x 600, not great on 27 inch
so i go into the options, bump up the resolution
i also notice a "widescreen 16:9" option, cool i say, my screen runs that, il tick that,needless to say as soon as i run half life 2 i lose picture and cannot change it back.....any ideas how to without re installing?
On a side note, how can i increase the resolution beyond 1280 on the options menu
