- 13 Jan 2004
- Leicestershire
i'm guessing it's not a competitor so it's ok to ask?
how do these things work?
reason i ask is this....
Car R reg ford Galaxy with 2007RDS head unit and steering column controls.
whats to go it:
JVC CD head unit about 5 years old (no jack plug so no ability for the steering column controls i'm guessing).
normal connections on back BUT:
when it comes to connecting to the CD wiring loom only the black power connector fits and works. the brown one - is that for the speakers? and whats the silver one and the yellow one both about half the size of the brown and black plugs?
i've seen in halfords there a connector for the 2007RDS unit but do i have to trace it back and remove it or connect the adapter which seems to be the right size as the silver one? would this enable the speakers to work?
in the car i have the following:
Black connector(power etc)
Yellow connector
Silver connector
the aerial (which DOESN'T need the adapter halfords specifies as it fits WITHOUT it which is why i'm questioning the fitment)
on the back of the stereo i have the following:
top connector
bottom connector
aerial(fits so sorted)
every kit i've tried fits the stereo but not the car.
help.
whats to go it:
Yellow connector
Silver connector
top connector
bottom connector
help.
