Halfway point in current build Help appreciated
24 May 2007
So, im halfway through my first build and im having a few problems identifying the various connections on my mother board.
Im using the Gigabyte GA_P35_DQ6 with a NZXT ZERO case.
Has anyone on these forums used the same combination of board and case and if so would they happen to have a decent picture of the completed setup.
The main problems im having is trying to find out how all the fans hook up to the motherboard and also the exact number of connections i need to make with the case front panel and the mobo.
I'd love to be able to finish this build tonight as a bank holiday weekend on the beer got in the way of my build!
I wuold appreciate any help with the above problem.
As my case and heat sink have 10 fans all together i am wondering do i connect them all to each other first and then to the motherboard or do i link them all and then connect them to the psu(Corsair HX 520W ATX2.2)
My fans have the 4pin connection.
ok so i have a few photos of where im at in regard to this build but how do i post them? #sorry if this is a stupid question but im not familiar with posting pics.
So here two pics i have of my current build, first one i just have the PSU and the heat sink installed, second one i have all components, not sure if you can fully see whats going on but you should be able to make out the fan connections.
I'd appreciate any help you could give regarding getting this build finished. Should i remove most of the components and start again?
