** HALLOWEEN WEEKEND ONLY DEALS - ROUND 8 - COOLING **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Time for the next round, cooling. Not that the Antec Liquid coolers are not currently in stock, but the stock will be arriving on Monday. So get your discounted products over the weekend and we will ship on Monday as normal.
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £42.98 inc VAT - STOCK ARRIVING MONDAY
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Was £49.99 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
Antec Kúhler H2O 920 High Performance Liquid CPU Cooler (LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+) @ £66.98 inc VAT - STOCK ARRIVING MONDAY
Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the
Kühler H2O 920’s performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
- Customizable RGB LED for brilliant illumination
- CPU Socket: LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Radiator Dmensions: 151 x 120 x 49mm
- Fan Dimensions: 120 x 120 x 25mm
- Air Flow: 110 CFM
- 3 Year Warranty
Was £79.99 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Xigmatek Dark Knight CPU Cooler (Socket LGA775/1156/1155/1366/754/AMD 939/940/AM2+) @ £23.99 inc VAT
The Black Nickel creates a very gentle and noble image, which also increases cooling performance. Like other H.D.T. series coolers, it comes with the advantage of light weight, easy installation, anti-vibration, performance and user friendly. Black Nickel causes a very gentle but also noble image, which also increases cooling performance. With anti-vibration rubber for fan and 3 in 1 application retention module design, Dark Knight-S1283V provides users not only easy and quick installation but also lowest noise level. Dark Knight-S1283V combines 120mm PWM fan, anti-vibration rubber, 3pcs ?8 heat-pipe and 3 in 1 application of Intel/AMD CPU. Anti-vibration rubbers prevent Fan vibration and also absorb vibration noise . Light weight. 120mm highly efficient PWM fan.
- Socket 775, 1156, 1155, 1366, 754, 939, 940 and AM2+
- Product Name:Dark Knight-S1283V
- Dimension:120(W) x 50(D) x 159(H) mm
- Heat Sink:Base Material;H.D.T. (Heat-pipes Direct Touch)
- FinMaterial:Aluminum Alloy
- Heat-pipe: 8mm
- Q´ty 3 pcs
- Fan:Dimension 120(W) x 120(H) x 25(D) mm#
- Voltage Rating 12V
- Speed 1000~2200 R.P.M
- Bearing Type Long Life
- Bearing;Air Flow:89.45 CFM (Max.)
- Air Pressure:4.1 mmH2O (Max.)
- Life Expectance 50,000 hrs
- Noise Level:30.1 dBA (Max.)
- 4 white LED
- Connector 4 Pin with PWM
- Weight:600g (w/fan)
Was £26.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
THIS NOW HAS SUPPORT FOR THE LATEST NVIDIA AND AMD/ATI GPU's
Gelid Icy Vision Rev 2. VGA Cooler (Nvidia GTX 5XX and ATI HD6XXX Series Support) @ £28.99 inc VAT
The ICY VISION includes five power heatpipes with 10 effective heat transmission channels and 85 individual 0.4mm thick high quality aluminium fins. This configuration ensures a faster heat dissipation from the GPU to aluminium fins. And thanks to the two 92mm S-shape fans that provide 20% additional air flow than traditional fans, the ICY VISION cools High End Graphics cards at a lower noise level than the original stock cooler.
- Compatible with Nvidia GTX400 series and ATI
- Five high performance power heatpipes
- Premium aluminium fins and pure copper base
- Two 92mm S-shape fans for 20% additional air flow
- Ball bearing for long life
- CrossFire and SLI compatible
- ATI Compatibility: ATI HD4850, HD4870, HD4890, HD5830, HD5850, HD5870, HD6850, HD6870, HD6950 and HD6970
- Nvidia Compatibility: 9800GT, 9800GTX, GTS250, GTX260, GTX275, GTX280, GTX285, GTX465, GTX470 and GTX480, GTX560 TI, GTX570 and GTX580.
- Air Flow: 67.14 CFM
- Noise Level: 26 dBA max.
- Fan: 2 x 9215 S-Shape UV Blue Fan
Was £32.99 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
620/920 are good. Thinking of changing D14 to one of the AIO water cooler due to clearance issue in the Outlaw.
I know the day my h50 dies these wont be on offer, think the gf would mind if I got her one for her rig and I tested it all the time in mine? hehe
Right I left the pricing as it is..... It will be going up at 5:30 now.
The stock has landed and all orders are shipping right now.
