halo 3 campaign mode
3 Feb 2004
Oxford
Hi,
Sometimes when I play with a mate in campaign mode the frame rate drops significantly and the game is very difficult to play. Anyone else having this problem? Is there a solution?
This sounds more like a connection problem. Make sure both your NAT settings are set to open and nobody id downloading anything. Have a google for your router and NAT settings and XBox live.
Keeping things tidy I will slip this question in this thread.
Can you gain the achievements for campaign scoring (score 15,000 points etc) in co-op mode?
Ta
Yeah its not the frame rate it sounds like a latency issue. I had it a few weeks ago, but it sorted itself out so I didnt need to do anything :)
Most people can host 4 player co-op no problem on all kinds of connections so the problem is going to be with one of your routers (not 100% sure, but its worth checking).
Ta
It is meant to be done in Co-op so yes :) It can be done either alone or with up to 4 players. The skulls you find will also make the game more difficult thus multiplying your score(s) (all depends on what ones you have active ofcourse :p)
although take note to get the acheivement you need the 15000 score yourself per player, not for the whole team
lol difficult being an understatement with all the skulls turned on with the game mode set to legendary :)
i get the frame rate drop occasionally, not sure why cos both mine and my friends connection are ok, no else downloading etc
Is there any specific port that needs to be opened on a router for the 360 out of curiousity?
