- 15 Nov 2004
- Manchester, UK
Hey all,
Quick question:
How can I avoid getting the 'halo effect' around objects that are against the sky when I select it (feathered) and darken it using the curves/ levels tool?
What I mean is when it is obvious that you've selected a section of the image and the feather can be seen, a feint white line between the subject and the sky which can be quite off-putting sometimes.
Any advice?
vinegar_tom
Quick question:
Any advice?
vinegar_tom
