Hamachi help please.
Caporegime
30 Jun 2007
Wales
Me and lin kare trying to set up hamachi to play risk2 (only works over lan0
We managed to log into the same hamachi network, but couldn't get the game (tried css too) to se the other computer.
Anyone got any help?
We're both noobs at this :o
Thanks guys.
Have you set your game up as a LAN Game ?? I know when a few of my buds used to play Supreme Commander over Hamachi, we had to set the game type as LAN.
It's because most games don't search for Hamachi's IP range I believe, but I'm not sure.
With all LAN games, check your firewall and port forwarding settings.
For CSS, you need to add your Hamachi IP to favourites in order for it to work or type the command sv_lan 0 in console.
For most other games, a direct connect via IP is often needed.
EDIT: For clarification, it's the Hamachi network IP of the guy with the server started that needs to be added to your favourites, no need to include the port, if you still can't find the server.
