Jelly made out of sailors? Ewww.Treefrog said:Why not Naval Jelly it and Hammerite on top of that? As Hammerite doesn't need a primer.
3rd one down?fatiain said:
fatiain said:
Order 24?AcidHell2 said:Thanks but only appears to be single cans, not a whole pallet..
fatiain said:Order 24?![]()
whole point of bulk buying is a reduced cost..More like sailors' jelly, which is worse.fatiain said:Jelly made out of sailors? Ewww.
OK then. Go to where you buy the £3.30 a pop ones, speak to the manager and ask him if he'll do you a deal on 24?AcidHell2 said:whole point of bulk buying is a reduced cost..
No silly, it's for dissolving belly button fluff.fatiain said:Jelly made out of sailors? Ewww.
Aha, gotcha. I used Hammerite over the spray primer on my previous bike - beautiful finish!AcidHell2 said:As I want A half decent finish... And reasonable long lasting protection.. It is for my car, Used up 2 cans in the last 4days. at 3.30 a pop it ain't a cheap method...
IainB said:Acid,
Not to sure which bits your painting but have heard VERY good reports on the bits that Frost sells http://www.frost.co.uk
Think they did a right up on the NSRA board about the whole rust protection / paintwork thing. Did you ask on the MMA board as to what everyone else is using?
2-pack epoxy would be your best bet I think. And probably the most expensive too, unfortunately.AcidHell2 said:Also is there some sort of lacquer to give a really hard impenetrable top layer?
