- 31 Mar 2006
- Sydney Australia
Being something of a lover of all things radio controlled and of things that fly I've always wanted a radio controlled airplane.
I have the small problem of living in a flat in the middle of London so I have neither the storage space nor the space to really fly a decent RC plane. I have also the minor issue of having to save for a wedding so I can't really spend any significant amounts of money on things that are considered by my better half as a toy. As we all know they are not toys but serious experiments in aerodynamics and a tool for learning.
A while ago I bought one of those foam faux RC planes that are shaped like an F22 Raptor and steers by changing the speed of a prop on either of the wings.
One of these:
Through a combination of crap skills and the aircraft being a pig to control I've given up on it and decided to try building my own. Looking around I came across these things, commonly know as HL Gliders (Hand Launched).
This particular one has radio gear in it and as such is a little beyond my means however it does interest me in as far as the design goes. It strikes me as both fairly customisable and also scalable. So the next trick was to hunt down some plans. It turns out that this is a pretty easy thing to find as there is something of a community out there for RC fliers and they seem perfectly happy to share them around.
I found a few on this site: http://f4bscale.worldonline.co.uk/hand.htm and decided to go with this plan:
It didn't seem too ambitious and being made out of mostly balsa I cautiously expect it to be fairly straight forward in construction. I'm going to take some liberties with the design, I will replace the main strut with a carbon fiber tube for some extra strength and am also considering cutting the guts out of the F22 Raptor thing and seeing what happens when you attach some motors to the wings.
Of course this is all extremely experimental and I have never done anything like this before so it might all end up with a poorly sculptured heap of crap that refuses to fly. I'll keep you all updated if you're interested.
One of these:
