- 1 Apr 2009
Hi chaps, starting ripping my DVDs, wondering about what settings to use as they aren't quite perfect.
Target file size : around 1-1.5GB for 90 mins.
It's basically 'High Profile' with Constant Quality = 19, and Constant Framerate = 23.976.
So again, any way to improve would be good. I found the picture a bit too sharp a bit saturated comapred to the original DVD, like some sort of high pass filter is on. It's not too bad, but I'm sure it can be improved at little cost (file size).
Handbrake 0.9.8 (2012071700)
Output Settings
Container = MP4
Large File = yes
Web Optimised = yes
iPod 5G support = no
width = 720 x 576
Anamorphic = loose
Modulus = 16
Cropping = automatic
Video Filters
Detelecine = off
Decomb = default
Deinterlace = off
Denoise = off
Deblock = off
Grayscale Encoding = off
Video
Video Codec = H.264(x264)
FrameRate = 23.976
Constant FrameRate = on
Peak Framerate (VFR) = off
Constant Quality = off
Avg Bitrate (kbps) = 1536
2-Pass encoding = on
Turbo First Pass = on
Audio (typically)
1 - English AC3 (5.1ch) - AAC - Dolby Pro Logic II - Auto - 160
2 - English AC3 (5.1ch) - AC3 Passthru - None - Auto - Auto
Subtitles (typically)
1 - English (VobSub) - No - No - No
Chapters
Create chapter markers = yes
Chapter 1
Chapter 2
Advanced
Encoding
Reference Frame = Default (3)
Maximu B-frames = Default (3)
CABAC Entropy Coding = yes
8x8 transform = yes
Weighted P-frames = yes
Pyramidal B-frames = Default (normal)
Psychovisuals
No DTC-decimate = false
Adaptive Quantization Strength = 1.00
Psychovisual Rate Distortion = 1.00,0.00
Psychovisual Trellis = 1.00,0.00
Deblocking = Default (0) / Default (0)
Analysis
Adaptive B-Frames = Optimal
Adaptive Direct Mode = Default (spatial)
Motion Estimation Method = Default (Hexagon)
Subpixel ME & Mode Decision = Default (7)
Partition Type = Default (Most)
Trellis = Default (Encode Original?)
Result Speed : 25 mins transcoding for a 90 minute video.
Plan is to see if I can get some improvements over the visuals, and correct the OP with the best settings I found.
Output Settings
Container = MP4
Large File = yes
Web Optimised = yes
width = 720 x 576
Anamorphic = loose
Modulus = 16
Video Filters
Detelecine = off
Decomb = default
Deinterlace = off
Denoise = off
Deblock = off
Video
FrameRate = 23.976
Audio (typically)
Chapters
Chapter 1
Chapter 2
Advanced
Encoding
8x8 transform = yes
Psychovisuals
Analysis
Dual Pass takes about twice the time (obviously), the quality is marginally better than high profile RF:19 with better or equal file size (Alien wasn't that much smaller).
Thank **** for my 2700K. What a champ!
