handsfree bluetooth car kit
22 Feb 2014
I am looking at the parrot MKI9100 or MKI9200 at the minute.
Does anyone have any comments on either (or both) of these units ?
Anything else I should be considering ?
I had the 9200 good piece of kit with only a couple small gripes, Not so easy to navigate on the go i.e if you want to change song etc but good for what it is, Didn't find the voice recognition bit any good though ie when you say a name you wish to call it comes up with a completely different name :) Does come with a little detachable monitor for security as well which was good
