OK, hi! I apologize in advance for the wall of text..
You guys have been incredibly helpful in the past when I have needed help, unfortunately I cannot remember my old account information or recover it since the email i registered with no long exists. Hopefully I can find some help here again!!!
After experiencing constant crashes and hangs while using my PC over the last few days, and toying with the idea of a format, today I booted to find the "system has recovered from a serious error" screen, where it prompts you to choose between safe mode, normal mode etc etc. After choosing normal,,,AND safe mode it tells me the system cannot be started because the file "/windows/system32/system" is missing. No idea why this has happened, but it is the final straw and the idea of a fresh harddrive sounds quite nice anyway.
Now for the real problem:
This format business is nothing new to me as I have this rig for 5+ years and have formatted successfully several times in the past, however this time, doing everything in the same way, after asking me wether I want to repair or just install, and agreeing to the user license, it hangs with the message at the bottom of the screen "Searching for previous versions of Microsoft Windows".
Have left it to it for the last hour, thinking maybe it is just being exceptionally slow this time, but nothing is happening at all. What is wrong and what can I do to fix this?!
Last point, I have tried to just repair the system, using the same process as above, however when I choose the partition upon prompt (number 1, the only one on my system), again the PC hangs and nothing happens. The only option is to cold restart the computer.
Any advice or solution is greatly appreciated.
