hanns g 19"ws
Most TFTs can go up to 75 but doesn't really make much difference, might as well stick at 60. If in Control Panel > Display > Settings > Advanced and Monitor it shows up as an available refresh rate when the checkbox Hide modes this monitor cannot display is ticked, then you can be pretty certain it is supported (note that available refresh rates can change depending on the resolution).
