Permabanned
- 26 Oct 2002
Can you get a chip from a usb pen sort of thing and use it to install windows on , would it be really fast or not
I have got a lot of junk on it
agreed, i don't think you'll be able to get much faster with current OS's (XP in mind) and current hardware.Raikiri said:Erm...if your very good at soldering and designed a PCB with an S-ata interface then yes... you can buy solid state hard drives but they are incredibly expensive.
Gigabytes Iram is probably the closest you will get, and it is marketed as "boot windows XP in seconds"... Mine only takes 5 second to load anyway with an s-ata2 spinpoint so right now there is little advantage
defragged lately?Stephen7372 said:My computer takes about 4 minutes to bootI have got a lot of junk on it
