Thanks for reading in advance...
I have this annoying issue with my PC, and google fu is failing me to identify the cause....
The failure
PC freezes, no BSOD, no error code, no warning, not triggered by loading/temperature
As soon as it happens, no new application loads.
I can change between chrome tabs a few times until it completely stops, then the whole screen eventually stops. Its as if the Hard drive stops communicating all together and works only off whats on the RAM until errors build up.
I have SSDs, i changed this 2 times with fresh windows install. On top of this I've changed the SATA ports, SATA cables, freshly installed windows.
Once this happens, immediately restarting shows a DOS prompt to say "hard disk not found, ctrl+alt+del to restart"
With the mains off, waiting a few hours (sometimes overnight) cures the issue. until it happens again in 2 to 3 weeks time.
The spec is as follows:-
CPU: i5 6600K (no clocks atm)
MB: Asus Z170I ITX Pro gaming (Latest and previous chipset drivers tried)
RAM: 2x 4gb DDR4 Vengeance LPX 3000MHz
PSU: Corsair RM650
GFX: GTX970
I really would like this resolved as it takes precious quality PC time away from me unexpectedly
Many thanks,
To add: It's really strange because I can do high load activities like gaming for ages without it happening at all. Yet after some period it just goes again..?
I dont want to RMA anything as I'm sure the item will be returned with no issues found..
The failure
PSU: Corsair RM650
GFX: GTX970
Many thanks,
