Hard drive failed, now no xp :(
8 Nov 2002
The harddrive on my Acer has failed so I've fitted a new one but when I use the reinstall disc's all I get is 'no operating system found' and cannot even get to the reinstall disc's. Whats to do????
I can get into the bios and change to boot from cd but I think because the acer partion is missing(new hard drive) then that must have had something on it so the the recovery disc's could be used
As soon as you turn on the pc, even if it doesn't show the bios screen, keep tapping f12 at 0.5 to 1 second intervals. That should bring up your boot menu on acers I believe.
The Acer restoration CD maybe looking for a Tattoo on the hard drive. Quite a common trick by certain main stream laptop makers to do this so that only replacment parts supplied by them can be used.
The other option you have is get an oem copy of Vista or XP and use the key you have on the underside of the laptop to activate the operating system, then get all your drivers from Acer.
Thats what I did with my laptop, gets rid of that pre-installed unwanted software.
