Hi, The hard drive in my late 2011 13" MBP Has failed, I've had a look on the Toshiba website and I've found out that I'll have to return the laptop to apple, the problem is that I've replaced the optical drive with an SSD and I can't find the optical drive to swap out with the SSD and it's caddy.
Will the product be accepted by Apple? Also are they likely to send off the laptop for replacement or just replace the hard drive there and then?
I would purchase a new hard drive and fit it myself but I'm trying to minimize on unnecessary expense at the moment as I'm saving for uni.
Cheers
Cheers
