which is better CCC or superduper free version?
No clue... it doesn't sound like a Mac tool I am familiar with.
Ahh tres cool... another bit of software from the makers of Carbon Copy Cloner. I really should look at his other apps!
A bit overkill for your needs I think - but if you need to restore over https!
but does disk utility not have the advantage of being able to boot from an image?CCC for free (and SD! for cost) unlike Disk Utility can also perform backup of selected items, and synchronise between the original and the backed up copy, meaning that in future backups it will copy only items that have changed since the previous backup.
You can make block-level copies of one partition to another; you can back up across a network; and schedule backups.
