Hard drive issues (not showing in windows)
15 Mar 2010
Bucks
Got a new harddrive the other day to make it 6 harddrives in my rig total.
the new harddrive worked first of all to do the partition and activiating in windows....but now if doesnt show in windows explorer at all :(
its in bios 100%
its also in the admin panel for storage but has not partition info only total size but if i try and format or change drive letter or anything i get:
op failed to complete bc DM console view is not up-to-date. refresh view
which i do, and the same message comes up.
weird thing is if i switch two disks around the same sata on the mobo it is always not showing in windows???(but appears in bios)
what have i done , any ideas? its like the sata drivers or something have thrown a wobbly.
Checked for an earth fault around that sata connector on the motherboard? Little metal pillar etc if used can cause odd behaviour like that. Sounds more likely to be hardware/cable related than driver to be honest.
