26 Jun 2010 at 18:19 #1 Strepsils Strepsils Associate Joined 27 Feb 2010 Posts 357 Is the hard drive dying? or is it something else
26 Jun 2010 at 18:21 #2 AS_Platinum AS_Platinum Associate Joined 5 Jun 2004 Posts 1,341 Location Hythe, Hants You positive its the hard drive and not the PSU? edit: reason I ask is that your pc will be drawing more current from the PSU when gaming.
26 Jun 2010 at 18:59 #3 Strepsils Strepsils Associate OP Joined 27 Feb 2010 Posts 357 I think its the hard drive as I'm suspecting the textures causing the hard drive to scream
26 Jun 2010 at 19:05 #4 RJC RJC Don Joined 29 May 2005 Posts 29,093 Location Kent I would go with the gpu screaming, is it possible to remove the drive and use it external to confirm.
26 Jun 2010 at 19:13 #5 Strepsils Strepsils Associate OP Joined 27 Feb 2010 Posts 357 my gpu is integrated I also think it is temperature related
