Hard Drive Mounting
19 Jun 2009
London
In my Antec 900 I was trying to remove the screws that are holding the hard drive in it's bay but I cannot remove the final screw, it just won't unscrew. It's already loose but it just wont come out and I cant see no way to get behind it and try to push it out. Any ideas? :confused:
Sounds like it's cross threaded.
You'll need to apply pressure while turning it to get it out. Maybe a pair of needle nose pliers or use a screwdriver to lever it while also turning it with another.
Or as a last resort use a small drill and drill down the middle of the screw and remove the debris afterwards.
