I think you need to select N when it asks you if you want to search for partitions. Then select P to list files (once you've selected this you can search each folder and select files to copy)
If you have no root folder you may want to find a different program. Testdisk will tell you if they are retrievable but you wont be able to copy them all across in one go if there is no single containing folder
