- 11 Aug 2007
Hey there
I am upgrading my PC soon (just waiting on the CPU and case now) and the only things I am taking out of my current PC are the DVD-Rom drive and the hard drive (as well as the PSU and graphics card but they were both upgraded recently). What I want to know is, when I plug this hard drive into my new build, it will be going from a single-core AMD setup to a dual-core Core 2 Duo setup, will everything work ok? It is running Windows XP Home edition if that has any effect on it. Or will it ask for updates or something when using the upgraded PC?
Thanks for your help and time.
, so demo , you are build a new PC from scratch and the only items that you are reusing are the dvd and hdd ?
