Hard Drive space mystery
29 Dec 2013
London
Saw a popup warning that my Hard drive on an old Samsung R720 laptop was close to full last week, after shimmying around a few files I freed up 2GB of new space yet received the same warning yesterday.
Deleted everything from my temp folder and recycle bin to free up a whopping 13GB of free space last night, but this morning it's already dropped to only 9GB free! :confused:
Note: using vista and normal programmes like firefox, itunes, dropbox etc
Any help would be amazing, it just seems like space is disappearing into thin air!
I've used WinDirStat for years since I spotted its uber colourful output on a colleague screen and asked what it was.
Brilliant tool for drilling down into your directories to discover where all your disk space has disappeared to.
Have you cleared out all but the most recent restore points (that is if you have that option after you select clean system files or something like that in disc cleanup) as that might give you a few gigs back.
I just had a quick run of WinDirStart and found a folder with a load of jpegs, and after a quick look online, seems to be a problem a lot of people have found.
Linky
Have a look in the folder and see whats there.
Simple but effective if your PC is using it, is to kill of Hibernation.
The file itself is several gigs.
on a CLI
POWERCFG -H OFF
run under adminand you will be sorted by a few gigs.
on a CLI
POWERCFG -H OFF
No more fastboot if you use this command on Windows 8. :(
