Hard drive trouble...
11 Dec 2003
London
Just installed a 3rd SATA HDD (bought from the OCUK members market) and suddenly, after transferring many files to it - I can no longer see it :eek:
any help very much appreciated
Did you change any settings in bios such has chaning from SATA, to IDE, etc this can sometimes mess with seeing the HDD in windows?
Checked and rechecked al connections, didnt mess with the bios
Going to reboot now - I should mention that the drive 'vanished' after a write error when I was moving a large 51GB block over to the newly added drive. an explorer window popped up saying that a particular file had not been successfully transferred and had been lost. no biggie in itself but the rest of the drive was no longer listed in My Computer, rebooting also confirmed this when the drive failed to POST as a device along with my other two drives
Are the other drives in RAID configuration?
I know that with my mobo, I still have to go into the RAID menu to set the drive to single array otherwise it wouldn't see the drive. Press F4 (or F5 - can' remember which) after the intial POST to enter the RAID menu.. You should be able to add it there as a single drive. That said, you have already seen it????
replumbed some wiring - swapping SATA connectors on the mobo etc and it has mysteriously reappeared. Hardly inspires confidence as a robust storage arrangement - ho hum
on a side note can you recommend a painless way delete large file/folder structures securely? ie with a 3-pass physical scrub?
that had crossed my mind too, as my DFI mobo defaults to a RAID menu - long time since i checked it - perhaps this is creating inconsistencies?
