Hard drive
You might try attaching the drive internally to a SATA port and see if it shows up. That assumes it isn't one of the USB drives where the USB is built into the drive's controller rather than being a separate bridge board.
Professional data recovery is an expensive proposition. You've really got to need the data to justify the cost.
its in a caddy but its making sclicking sound for a few sec's
Probably means you've moved the read/write heads so they are stuck. It's fixable but your meant to do it in a clean room to prevent dust.
There's are probably a workaround, I suppose a dehumidifier may do the trick
