- 18 Nov 2011
so recently, it's been getting a lot worse... my PC will just randomly freeze, while loading up, while playing games, while sitting on the desktop. When i say freeze, i mean totally... no sounds, no reset, no response everything sticks on exactly as it is until i manually kill the power to the machine.
the only errors i get in event viewer are Critical Kernel Power 41 (63) , which i've read is more of a response than a cause, and distributedCOM 10016 error which i think is software permissions, but they're only errors.
i5 6600k
980ti
Corsair 1000w PSU (2 years old)
Corsair vengeance ddr4 16gb 3200 (not set to XMP or clocked)
samsung m.2 500gb
now, it is all watercooled... but the temperatures are definitely not an issue, this will happen on the first boot up of the day within seconds on some occasions.
i've run various tests on things, gpu burn, cpu burn... memory test on the intel management app and i've re installed windows before now... the PC performance isn't effected, it's literally just a random hard crash... i've no idea now guys.
any suggestions? thank you so much in advance
i5 6600k
980ti
samsung m.2 500gb
