Harder, Better, Faster, Stronger
2 Aug 2013
Helloooo,
I've recently started my quest to get rid of my wass ass and tone up! So I shal be posting on here starting with dead lifts etc tomorrow.
Appreciate any feedback, tips etc for someone who loves food far too much
Taaa
So second time dead lifting under the tutorial of monkee.
Stats as follows
Back- Dead lifts
8x 40kg
5x 60kg
5x60kg
2 x 80kg
5 x 60kg
5 x 65kg
5 x 70kg
5 x 60kg
5 x 40kg
Short back session but monkee couldn't handle the pace ;)
Yeah I'm trying to sort form out ATM! But the temptation of getting higher weights took over and my laziness of changing weights took over
From what I've heard delvis, it don't take much! Do you even lift bro?!
Bro trainings getting hit hard from tomorrow! Had issues with an ongoin knee prob and work commitments!!! Pls forgive.
No gym for home, work out floor with 30, but is it for 20 like 30 lb when you no lift it to be for men, for 30 lbs instead? or half is 10 for 20 pounds?
UMM HOW i word this... ok u take 20 lbs no lifting for 30lb if guy, so divide 2 u dont sit, u get 10 but for guy it no 30, so 20 would be for guy if u werent a girl ?
Erm.. What?!!! Do u even English?
Exactly this. To confuse these things would be the end of gains.
Leg day
Squats:
10 x 40kg
10 x 40kg
8 x 50kg
8 x 60kg
8 x 70kg
8 x 60kg
8 x 50kg
10 x 40kg
Glute ham raises:
3 sets of 8 no weight
Leg press:
8 x 120
8 x 120
8 x 120
Leg curl
10 x 20kg
10 x 30kg
10 x 30kg
TRX Lunges per leg
3 sets of 5 each leg
Core work with a ball. And now for a lovely 9 hour shift at work!!!
