Hi All,
Posted a while back for some advice and it was brilliant, thank so much! Due to circumstances I'm only now getting round to actually testing the full rig. I've already done a lot of leak testing, identified and fixed a few issues (almost all missing washers!) but I am stumped at one problem. The output from my pump goes straight into my radiator but the connection at the radiator end is leaking quite profusely.
As it is leaking I haven't been able to get enough water in to actually complete the loop, so the pump runs dry quite quickly and the leak is definitely worse when the pump is pumping - however water still seems to leak out constantly as the water in the radiator drains back out. I'm baffled and have checked everything, washers are all in and correctly fitted, the collar (monsoon hardline fittings) is glued securely. Does anyone have any ideas or tips to check?
Huge thanks for any advice!
